Skyhaze001 Posted July 4, 2013 Share Posted July 4, 2013 After giving the V to a mechanic to replace my driveshafts, he has told me that it's actually the diff bearing in the gearbox that is causing the horrible amount of noise. So I'm after a gearbox for a 98 spec V with an LSD. On a side note he has quoted me around £800 to get the bearing replaced, is this a good price? Might see about getting it rebuilt if theres not going to be too much difference in price to buying a new gearbox Link to post Share on other sites
Skyhaze001 Posted July 7, 2013 Author Share Posted July 7, 2013 Bump Link to post Share on other sites
Jordk Posted July 13, 2013 Share Posted July 13, 2013 You'll be able to pick up a gearbox much cheaper than that mate. I've got a non LSD box in good nick for £200 if you're interested? Link to post Share on other sites
morgey Posted July 13, 2013 Share Posted July 13, 2013 Not sure on the lsd boxes but if you were on it you could drop a box in an hour. crack it open in another (use taggys guide) get the diff out and replace the bearing in another (around £100 i think) then 3 hours back together so say 6-8hours (max) labour at £40ph? plus parts should really only cost £450 to do diff bearings Or man up and have a go yourself Link to post Share on other sites
Skyhaze001 Posted July 14, 2013 Author Share Posted July 14, 2013 @Jordk - Unfortunately I need one for an LSD otherwise I would have had it off you! @Morgey - If I had an ounce of mechanical knowledge I would give it a go myself, unfortunately I would probably break something else in the process of trying to fix it thanks for the info though, if I can't find a new gearbox for it soon I'll have a look around for someone to repair it. I think it's about to give up judging by the amount of noise it was making yesterday! Link to post Share on other sites
