Ok let me explain properly look at this image guys and girls
>https://www.google.c...B9-HBVI1pgB17M:
Regarding the left two blue boost solenoid boost vac pipes for the hi low function I do not want to do a bypass I like the hi low button function.
BUT since I have fitted and relocated the aircfilter to in front of my grille using a samco silicon pipe straight to the turbo I have no place to plug the bottom vac pipe as I have removed the original air intake pipe where it did plug...
Where do I plumb it now? Do I use a t piece if so where do I plumb it back into ?
He means the Vacuum hose that plugs into the top of the efi pipe and I don't think it needs to go anywhere, as its just a dump for the throttle body iirc. Could be wrong tho
