1990timeismoney Posted July 6, 2013 Posted July 6, 2013 Hi all just received my depo boost controller the display is in bar but when setting the boost the value goes really high and unsure of how its calculated wanna set it to .7 any help much appreciated. luke Quote
Matt1878 Posted July 6, 2013 Posted July 6, 2013 I got one of these and it was SHOCKING! Couldn't hold boost and always spiked. Went to tuning developments for a meet and put it on the rollers. Boost controller was pathetic so I just got rid ASAP.If you want to give it a go... Best setting your actuator low and then adjust the gains on the controller going up in 10's. see how each 10 adjusts boost and then go from there. Quote
1990timeismoney Posted July 6, 2013 Author Posted July 6, 2013 Cheers for the info mate Im use to greddy controllers and this controller is all over the place. Set the screw on the back to 1bar then I set the gain to 65 and still all over the place Quote
Matt1878 Posted July 6, 2013 Posted July 6, 2013 Cheers for the info mate Im use to greddy controllers and this controller is all over the place. Set the screw on the back to 1bar then I set the gain to 65 and still all over the placeI found this too.. I allowed 1bar max .. Had gain1 at 0 (actuator pressure) which was .4 bar and then gain2 I tried to get to .9/1bar and it just wouldn't hold. Was shite. Started spiking to 1.4bar on a ct9 lol not good. My best advice would be to get your money back if you can and save up for a blitz or greddy setup. It's not worth having a cheap piece of kit that will potentially blow your car to bits. Quote
1990timeismoney Posted July 6, 2013 Author Posted July 6, 2013 Think I mite take your advice cant afford for it to start boost spiking etc.The value in which the boost at dont make any sense to me they should of made it the same as other boost settings Quote
