turbo_time Posted September 24, 2007 Posted September 24, 2007 what causes compression surge because i have alot of it and it sounds awsome but i fear it will kill my turbo after a while.im guessing i get rid of it by using a after market b.o.v but if it does not cus that much damage i will leave it cus its sounds great ;) does it effect the performance of my car ? Quote
gaz Posted September 24, 2007 Posted September 24, 2007 Its compressor surge pal, basically caused by air returning over the turbo blades instead of being vented, Some dump valves will still allow it to do it anyway mate, just leave it and enjoy it haha Quote
turbo_time Posted September 24, 2007 Author Posted September 24, 2007 so im guessing theres no real danager to my turbo then ? surely if the air passes back through the blades it slows the spin up thus affecting performance ? ;) Quote
Glanza_Ragger Posted September 24, 2007 Posted September 24, 2007 so im guessing theres no real danager to my turbo then ? surely if the air passes back through the blades it slows the spin up thus affecting performance ? ;)It doesnt affect spooling at all.Its only when you let off the throttle, not all the pressure will be dumped, so the only way it can go is back through the turbo..Hench compressor surge / turbo chop etcIt will allways affect the turbo to a small degree, but theres not much you can do about it.Play with youre bov spring tension and thats basically all you can do. Quote
