Item For Sale:
Forged 4efte engine built by dave@tmdevelopments(r.i.p)
Item Condition & Description:
Very good strong engine runs sweet as a nut.
Doesnt burn no oil or coolant, engine is in car still so can be seen and heard running.very strong engine. Feel free to come have a look before removal or compression test too if you like.( will be removed soon) I will remove upon deposit /full payment
Engine will come with distributer etc and also has race spec rocker with fittings, also the plugs are new, fuel rail injectors starter etc
Spec is
*Wiseco Racing Low Comp Forged 74.5/75mm Pistons
* Wiseco Racing Piston Rings, Pins and Clips
* Scat Forged Conrods with ARP 2000 Connecting Bolts
* 1.2mm head gasket
* New Complete Cambelt/Tensioner/Idler Kit
* New Head Bolts
* New Toyota Full Engine Gasket Set
* New Toyota Oil Seals
* New Water Pump
* New Toyota Oil Pump
* New Oil Pressure Switch
* New Thermostat
* New Toyota Valve Stem Oil Seals
* New Uprated ACL Bearings ( Mains, Bigends and Thrusts)
* Crank Reground(if needed) and Polished
* Block Professionally Rebored and Crosshatch Honed
* Cylinder Head Professionally Rebuilt
* Block chemically Cleaned and Painted
* Rocker Cover Chemically cleaned and Painted
* Suitable For Up To 400hp With Correctly Tuned Supporting Modifications
Price:
£1450 cash
£1550 pallet to uk
Payment & Shipping Details:
As above , shipping included.
Preferred bank transfer.
Edited by Hawwy
