when i pushing up the car, the engine lights will flash, then i go to check the car computer, it said the turbo sensor problem, but i dont know where it is. Every times lights on i will restart the engine, that was gone, anyone know how to fix it? thank you
Hi Mate...
It sounds like your on the early stages of fuel cut!
Fuel Cut is a limiter designed to protect the engine from being damage from building too much boost pressure...
If you creep up to 0.9 bar of boost, you will sometimes get a EML light. Anymore, you'll fit fuel cut itself which will feel like a missfire...
Have you got a boost gauge, what boost level are you running?
Is the car stock?
Yes...i can feel fuel cut when that light on, , i see it arround 0.8bar boost for that, and sorry for my explain is so hard to understand for you and my english is not good.
Thank you for your understanding.
The car almost stock for engine, the turbo is stock, just change suspension, and exhaust, boost gauge, HKS BOOST CONTROLLER, TURBO TIMER.
