ABS removal kit :)
Got home today to find the kit had arrived, cheers Mike top work :D
Got it all fitted soon as I had 5 mins free really, one thing I will say is that line 3 could of done with being an inch longer but I've sorted that with a spacer now so all good.
Few pics:
D4D612AB-3CC7-4137-AEF6-DBF1B0D2B409-845
Empty space, not sure what to do with the plugs and boost solenoid tho.
7AB5124E-19D9-4CE1-96C1-207914FE499A-845
Once again top work from the lads at TD, cheers again :)
Cheers rob, it worked out at just over £100 all in which is pretty good considering all the piece parts off an NA from Toyota are around £90.
Yeah I can imagine it'll be a bit of a pig to do with the lump in there.
I might have mate I'll have to read the instructions again but it's sorted now anyway.
Yeah it is, I need to have a nicer braided line made up but that'll still do the job
  • 3 weeks later...
have you got your engine in yet? line 2 as you have it here sits up against the inlet manifold,
And seems very tight if you pass it around the other side of the master cylinder. Not sure which way its designed to go
Mike can you confirm?
mikes away till next tuesday.....
Nope engines not in there yet so can't really confirm.
As said mike's away so could be a case of firing him a pm just to notify him of the thread and see what he can do when he's back.
