A L 3 X Posted July 30, 2013 Posted July 30, 2013 Right, as I made a topic before I have a weird knock when I set off, now I noticed the other day the engine mount on the drivers side by the Cambelt cover was torn, took it out and it was almost in two pieces, I got another one from a member on here which looked split but not as bad, as a temp measure, now within 20 mins of having it fitted and taking it for a drive it's split the same if not worse?Is the engine mount my only issue or is something causing this? Hard to tell with the replacement also being damaged but I don't wanna waste my money on a full set of engine mounts if something else is causing it, the bottom mount looked ok but never checked the gearbox top one? Quote
akyakapotter Posted July 30, 2013 Posted July 30, 2013 Poly bush them all won't have problems of tearing them then Quote
A L 3 X Posted July 30, 2013 Author Posted July 30, 2013 Reckon that's my issue? Could that be causing the knock? I just don't want to suffer the vibrations im of polybushed ones unnecisarely lol Quote
akyakapotter Posted July 30, 2013 Posted July 30, 2013 I'm not to sure bud all depends on how much your engine moves and an already split mount wouldn't take much to split. you get used to Polly mounts just make sure you have foam tape to stop rattles and getting used to gearbox wine lol Quote
A L 3 X Posted July 30, 2013 Author Posted July 30, 2013 Yeah I Spose might have to get some then I reckonYeah that's it I hate all rattles n shit, can you buy new standard ones? Quote
akyakapotter Posted July 30, 2013 Posted July 30, 2013 Yeah I Spose might have to get some then I reckonYeah that's it I hate all rattles n shit, can you buy new standard ones?You can but I'd say they are expensive and it's prob down to how much torque you produce so updated is the best bet or Trd ones if there still available Quote
akyakapotter Posted July 31, 2013 Posted July 31, 2013 Yes mate Trd made engine and gearbox mounts was a set for sale not so long ago not as much vibration as poly but stronger than stock Quote
akyakapotter Posted July 31, 2013 Posted July 31, 2013 No I was suggesting Alex should buy some hahaAh lol I have no idea maybe see If Iddy can sort you out Alex Quote
