i was wondering what would be the highest bar i should be running my 98 glanza on with thew following mods.
it currently runs 0.6 bar
mods:
front mount air filter
front exit exhaust
hks adjustable actuator
hdi fmic
blitz dump valve
zisco ramhorn ct9 mani
walbro fuel pump
magicore ht leads
any help is really appreciated :D
Lancee
U need to add a fcd to ure list then u should be nearly on ure way to run more boost.has been covered a lot of times so if u need more help then do a search. :)
personally i like the look of the Gizzmo MS-2 if you decide you want to run over 0.8bar
fuel cut defender and boost controller for £200
