AdamB Posted August 5, 2013 Posted August 5, 2013 I know this has been covered millions of times, but I can't find what I'm looking for, seems as if all the links in the How 2's section are dead and are of no use. I picked up an N/A sportif without a rev counter, am I right in thinking that the starlet CD dials are a straight swap with no messing about with wires? Also the glanza/paseo dial swap need some wires switching around, does anyone have a guide which works as to what wires on what plugs that need to be swapped? ThanksAdam Quote
rmsnoel Posted August 5, 2013 Posted August 5, 2013 In the how to section. The SR-CD clocks need 6 wires swapped around but its really easy. Sometimes its a straight swap but its always best to check your wires first.Paseo needs a few more wires swapped around but again its fairly easy.You dont need to cut wires if u poke out the white security blocks in the loom plugs and then use a womens hairclip to poke out the plugs. Ill post a photo in the how to thread Quote
cherrye10 Posted August 9, 2013 Posted August 9, 2013 I have a reflet, ie a Japan import cheapest spec which I am upgrading. Want to swap a glanza cluster, but from what I read here, is a sportif one easier to fit? Imp thing for me is uIau Iu got a rev counter. Will consider both options Quote
AdamB Posted August 9, 2013 Author Posted August 9, 2013 The sportif doesn't come with a rev counter mate. The sportif probably is an easy swap but if your looking for a rev counter it doesn't have one.Starlet CD/Paseo/Glanza dials fit with some wire moving from what I've seen, all have a rev counter. Quote
