Need a little help where is the best place to use trolley jacks and stands on front eg wishbone, toe hook, cross member or jacking points on sill cheers
I usually use the toeing eye to jack and under the back of the wishbone for the stand. If you have a jack with the rubber pad then you can jack off of the center of the cross member
The sills just get bent if using trolley jacks without rubber pads on them
Edited by morgey
Where the wishbone meets the chassis at the back closest to the middle of the car it meets the chassic theres a big bolt, i put my jack on that...
axle stands on those big metal guards that are bolted to the chassis rails
