Tuning Developments
Stage 1 4EFTE Rebuilt Engine Specs:
Wossner 74.5mm Low Compression Piston Kit with Rings and Pins
Scat 4EFTE Forged Conrod Kit with ARP Rod Bolts
Genuine Toyota Headgasket
Genuine Toyota Full Gasket Kit
Genuine Toyota Oil Pump Kit
OEM Water Pump Kit
OEM Cambelt Kit inc Idler & Tensioner
OEM Headbolt Kit & New Washers
ACL Main Bearing Kit
ACL Big End Bearing Kit
ACL Thrust Washer Kit
Fully Machined and Polished 4EFTE Bottom End
Fully Stripped, Cleaned and Rebuilt 4EFTE Cylinder Head to Standard Spec
Block, Head and Rocker Cover Cleaned and Painted in Tuning Developments Black and Silver Theme
This engine is rated to approx 250bhp with the correct supporting modifications (turbo setup, fueling, engine management etc)
Price is £1895 Inc Vat, Plus Delivery
Or
Fitted Price is £2195 Inc Vat, Drive in Drive out service Inc all Fluids
(Price you see is the price you pay)
Stage 2 4EFTE Rebuilt Engine Specs:
Athena 1.2mm Uprated Metal Headgasket
ARP 2000 Uprated Headbolt Kit inc New Washers
OEM Water Pump Kit
Block, Head and Rocker Cover Cleaned and Painted in our Tuning Developments Black and Silver Theme
This engine is rated to approx 320bhp with the correct supporting modifications (turbo setup, fueling, engine management etc)
Price is £1995 Inc Vat, Plus Delivery
Or
Fitted Price is £2295 Inc Vat, Drive in Drive out service Inc all Fluids
Stage 3 4EFTE Rebuilt Engine Specs:
ARP 2000 Uprated Main Stud Kit
OEM Water Pump Kit
Fully Stripped and Cleaned 4EFTE Cylinder Head Rebuilt to Custom Tuning Developments Race Spec
This engine is rated to approx 400bhp with the correct supporting modifications (turbo setup, fueling, engine management etc)
Price is £2995 Inc Vat, Plus Delivery
Or
Fitted Price is £3295 Inc Vat, Drive in Drive out service Inc all fluids
I got this
Wiseco 74.5mm forged pistons
Scat forged rods
Arp headbolts
Zep 1.2mm headgasket
CRUISE camshafts
Custom shims to suit camshafts
Crank balanced
Acl bearing
New toyota oil pump
New water pump
Full toyota engine gasket set
£2000 - cams alone cost more than£1000
I have this mate :)
Forged 5efte
Weisco 75mm pistons
Pec rods
Acl bearings throughout
Arp mains
Arp conrod bolts
Arp headbolts
Compley balanced bottom end
Baffled sump
3 angle valve job
Port and polish
265 speedvision cams
port and polish intake
blitz active clutch
£2000
Does anybody know how the tuning developement rebuild works? Do I send my engine to them to build it or do they take mine and give me one they have already rebuilt or what?
I'm still shopping round for a forged engine but I'm heading towards TD
That's handy I'm in south Cumbria, is the engine run in or anything and what will it come with?
Pm me your number or pm me mate
And yes its run in and its been run jn by tuning developments and also mapped by them
Edited by Hawwy
