KSport 6 pots mint,Toms steering,3 point rear brace mint,H&R hubcentric spacers
^^They are hubcentric ones mate....if anything you need shorter stock bolts as these fit over them and then bolt down, the spacer has its own studs at the original length. I'm running these 25mm on the rears and 20mm up front (stock front bolts needed shortening to accommodate the 20mm ones!)
What size ar they and u got longer studs and all that for them.?
20mm hubcentric, the bolt down to hub with supplied bolts , and wheel bolts to spacer
Stock bolts can be used for wheel to spacer
Edited by Hawwy
