smb2011 Posted August 15, 2013 Posted August 15, 2013 Have a lsd box just fitted with 2.0l of lsd oil and im getting a grind in 3rd if i go from 2nd into 3rd at high revs booting it, it wont grind goes straight in going slow into neural into 3nd softy its fine but when going into 3rd from 4th it grinds but if u do it slowly it dont grind at all ? What is the problem? Maybe clutch not bleed enough ? Or slave cylinder naff maybe swap my old gearbox one and see if its that not allowing clutch to disegage ? Or not enough oil in the box but 2l for a oem lsd is enough anyone can help?? Quote
SDD Posted October 6, 2013 Posted October 6, 2013 Mine does the same and i have no idea what it is ... all i could think is that the sycro has gpne on 3rd Quote
Glanza-Ben Posted October 6, 2013 Posted October 6, 2013 Yea does sound like the syncro has gone seems to be commen on starlets Quote
yaristurbo Posted October 7, 2013 Posted October 7, 2013 (edited) Yep synchro they mesh a lot better when going steady with shifting when trying to slam it it will gring as the gears will be not bring helped by the ring at all Edited October 7, 2013 by yaristurbo Quote
micky boy Posted October 7, 2013 Posted October 7, 2013 How was your other gearbox for changeing gears? The suger cube can also cause it to crunch if theres loads of play Quote
