3rd gear grinding ?!?!?
Have a lsd box just fitted with 2.0l of lsd oil and im getting a grind in 3rd if i go from 2nd into 3rd at high revs booting it, it wont grind goes straight in going slow into neural into 3nd softy its fine but when going into 3rd from 4th it grinds but if u do it slowly it dont grind at all ? What is the problem? Maybe clutch not bleed enough ? Or slave cylinder naff maybe swap my old gearbox one and see if its that not allowing clutch to disegage ? Or not enough oil in the box but 2l for a oem lsd is enough anyone can help??
  • 1 month later...
