Flynn Posted August 15, 2013 Posted August 15, 2013 How low do things get before the need for a panhard rod?Fitting a Glanza rear beam to my SR........now i've never seen one under the SR but can see what looks like a mounting point for one on the Glanza axle, did they come with panhard rods fitted as standard? and will there be somewhere for the other end on the SR chassis? Quote
mikey4410 Posted August 15, 2013 Posted August 15, 2013 I fitted one quite early on,then that way when u do start lowering and setting ride heights etc and then get alignment done you will have the adjustment there with no probs Quote
Chris Green Posted August 15, 2013 Posted August 15, 2013 I'm in desperate need of one - I think I have a 40mm drop and with 50 profile tyres the rear driver side wheel catchs the arch. Quote
mikey4410 Posted August 15, 2013 Posted August 15, 2013 If you have a glanza or the ep91 shape then roll ure arches dude.i have and you gain alot of clearance. Quote
Chris Green Posted August 15, 2013 Posted August 15, 2013 If you have a glanza or the ep91 shape then roll ure arches dude.i have and you gain alot of clearance. Ive heard the paint gets damaged doing that? Am I not right in thinking the panhard rod brings the axel back inline? Quote
Flynn Posted August 15, 2013 Author Posted August 15, 2013 My SR's dropped as low as it can be (Island roads are mental shit) on D2's without a panhard rod (SR drum rear beam set-up) but am wondering if the Glanza axle will need one? Recently spaced the rears by 25mm too so thinking i may get scrub without one? Quote
mikey4410 Posted August 15, 2013 Posted August 15, 2013 The paint on mine didnt flake other than a tiny bit,use plenty of heat with hairdryer and proper arch rolling tool and u wont have trouble. Quote
Flynn Posted August 15, 2013 Author Posted August 15, 2013 Was gonna get the arches rolled....think the paint should be ok if done professionaly?And i thought the panhard was to bring the rear inline too? Quote
mikey4410 Posted August 15, 2013 Posted August 15, 2013 As i said if you roll arches the extra clearance is very helpful.prob an extra 13-14 mm each side.really worth doing.DONT USE A BASEBALL BAT TO ROLL ARCHES THOUGH.lol.soo many people think its fine but its not good Quote
Flynn Posted August 15, 2013 Author Posted August 15, 2013 So what are we saying then......do I need to run one and will it fit the SR chassis? Quote
mikey4410 Posted August 15, 2013 Posted August 15, 2013 i would get one buddy, because as i said even if you dont need it now it it will good to have it on there.there not to bad price wise especially second hand.if your gonna go lower or wheel space,or already have done then do it.also get those arches rolled. i got my panhard second hand for 60 quid i think. just needed a lick of paint Quote
Flynn Posted August 15, 2013 Author Posted August 15, 2013 i would get one buddy, because as i said even if you dont need it now it it will good to have it on there.there not to bad price wise especially second hand.if your gonna go lower or wheel space,or already have done then do it.also get those arches rolled. i got my panhard second hand for 60 quid i think. just needed a lick of paintIs yours a Glanza mate? Quote
