lukeglanzav Posted August 16, 2013 Posted August 16, 2013 My oil light flickers when on idle and trys to cut out Recently i have taken off my exhaust manifold and intake mani fold and injectors Also the rocker cover the rubber oil seals what are in the rocker cover have been sand blast and remain no more these seals go around the ht leads which prevents oil leaks what sort of things could i be looking at what is causing yhe problem please help me asap Quote
jellybaby Posted August 16, 2013 Posted August 16, 2013 Does the revs drop ? Could b mainly things ie alternator failing to charge bat / fuelling. Does it do it when hot only or cold ? Quote
AdamB Posted August 16, 2013 Posted August 16, 2013 Check for vac leaks around the intake manifold if you took that off, and around intercooler joiners. Quote
lukeglanzav Posted August 17, 2013 Author Posted August 17, 2013 I rung racetech and they seemed to think it was bottom end his he having my pants down or could this actually be the problem ? Quote
lukeglanzav Posted August 17, 2013 Author Posted August 17, 2013 It only does it wen hot mate from a cold start it runs at like 2k :s Quote
AdamB Posted August 17, 2013 Posted August 17, 2013 Whats it idle at when warm?When was the oil last changed? What grade was used? It could well be the bottom end bearings being out of tolerence causing a loss in oil pressure, however that is the most extreme case, so obviously easier to deal with other cheaper alternatives first. Quote
lukeglanzav Posted August 17, 2013 Author Posted August 17, 2013 Its at drops to 500 sometimes cuts out Ive decided to break it now mate Going to pick up my supra on saturday. Quote
