iamlegend Posted August 16, 2013 Posted August 16, 2013 Gonna fit this I think...can you not use the oem bracket position at the bottom for the civic rad to rest on?? Or does that defo need cut off??Also the top brackets what's best with out using jezza brackets as seen it done? Is cable ties any good?? Ratty but for time been?? Quote
akyakapotter Posted August 16, 2013 Posted August 16, 2013 I don't have have a bottom bracket just one on the top Quote
iamlegend Posted August 16, 2013 Author Posted August 16, 2013 So did you cut the oem bracket for the oem rad?What's it leaning on then?? The bottomHose and top hose with bracket?? Quote
akyakapotter Posted August 16, 2013 Posted August 16, 2013 didnt cut off any brackets bottem hose holds the bottom in and top is held in with that bracket / bit of metal its not going anywhere Quote
iamlegend Posted August 16, 2013 Author Posted August 16, 2013 Just read can use the oem mounts so should be kool What bracket did you use for the top mate? Quote
akyakapotter Posted August 16, 2013 Posted August 16, 2013 no idea mate mike at td put it on for me when i was up there just looks like a bit of metal bent to the right shape Quote
