Ep91kez Posted August 21, 2013 Share Posted August 21, 2013 Hi guys My head is cracked around one of my exhaust manifold studs and is leaking a tiny bit of oil. would this cause the exhaus to smoke a little on start up or is it likely to be the valve stem seals?I have a spare head a brand new head gasket and brand new stem seals what else would i require to change the head? Also how hard of a job is it? cheerskez Quote Link to post Share on other sites
mikey4410 Posted August 21, 2013 Share Posted August 21, 2013 (edited) its not a hard job,you need headbolts also as these are not reuseable mate. to replace with new stem seals you need valve spring compressor. Edited August 21, 2013 by mikey4410 Quote Link to post Share on other sites
