mikehardy92 Posted August 23, 2013 Posted August 23, 2013 Ok so this is my first starlet and I was going to keep it as it was when I bought it..... But I think we all know that never lasts long hahaThis is the car when I got it But pretty soon I got bored of it and was looking into forged engines and td04 kits And then one fateful evening (8 hours before I set off for USC at Santa pod) the engine decided it didn't want to work any more. So I got the car towed home by a mate and after we got back from USC we set about finding the problemCouldn't find anything on the face of things e.g engine was timed, oil was a bit thick but seamed ok ect.We then decided we would just take the engine out and strip it. Ok so that was the engine out and then we started to strip it....we didn't have an engine stand at the start haha This what we found when we took the head off...Who can see the problem here? HahaNext we took the sump off to find a lovely mix of things Little end, most of a con rod and bits of bearingsThe rest of a rod and a shattered pistonthe crank (the culprit) We believe that due to an oil leak/ oil pump that there wasn't enough oil pressure to get oil to this end of the crank so it's got dry, expanded and shattered everything around it There is also a large chuck missing from the bottom of the cylinder, can't really see it in the picture ok so after finding all this mess I decided to just find an already built engine and go from thereWill update again once I pick the new engine up tomorrow Quote
ro55ifumi Posted August 23, 2013 Posted August 23, 2013 Gutted for ya but hope to see it evolve John Quote
mikehardy92 Posted August 27, 2013 Author Posted August 27, 2013 Ok so I picked the knew engine up on Saturday, TD stage 2 forged, with cruise cams. And got it mounted in last night, just needs plumbing in tonightI also got a few extra goodies to fit,Adjustable FPR225lph fuel pumpBailey bovGreddy Emanage Ultimate , I will post some pictures when I'm home from work Quote
mikehardy92 Posted August 28, 2013 Author Posted August 28, 2013 Got the car up and running tonight, idle is a bit rough because of the cams but I can live with that for now,Will be getting fitted tonight hopefully Quote
mikehardy92 Posted September 24, 2013 Author Posted September 24, 2013 Ok so it's been a while since I've updates this but not much has really happened, I've got a few pictures or the engine in and a couple of other things but nothing major Engine inFuel pressure reg on E-manage ultimate (still need to get mapped)3bar map sensorI took the car to tuning developments at the weekend for a dyno run and got mixed results, not what I was expecting but gave me something to work off.Going home tonight to sort out my wonky inter cooler and piping Quote
