Hey guys, I just got an Toyota ep91 Carat and my left reverse bulb is blown. I tried locating the socket is to remove the blown bulb, but it seems to be where I cant reach the socket. If you guys know how I go about changing the bulb will be greatly appreciated thanks much.
Hey Phil thanks for replying. I did pop the the plastic trim piece off, but the bulbs i can change are the indicator bulb and brake bulb but the reverse bulb socket seem to be hidden i just cant get to it from the trunk. I was pulling the plastic boot from outside but i feel i might break it.
These are the light i have
http://www.ebay.com/itm/JDM-TOYOTA-STARLET-CARAT-EP91-TAIL-LIGHT-RARE-ITEM-FACTORY-OEM-/190884237022
http://www.ukstarletowners.com/topic/242-jdm-starlet-carat-style-rear-lights/ " I just cant access the reverse light socket the way the light fits it is hidden behind the metal in the trunk
