hutchy1990 Posted September 5, 2013 Posted September 5, 2013 Hello I just bought some new rear brake discs and I was wondering can you remove the bearings out of the old brake discs as the new ones don't have them in or do you have to buy newCheers Quote
davehart Posted September 5, 2013 Posted September 5, 2013 You should have got new bearings with your new rear discs? I did when I got some new ones for mine, but then again that was 6 years ago Quote
hutchy1990 Posted September 5, 2013 Author Posted September 5, 2013 I thought the same mate but they haven't strange like Quote
AdamB Posted September 6, 2013 Posted September 6, 2013 I have heard that you only get the bearings if you buy OEM Toyota ones. I could be wrong though. Quote
Idrees Posted September 6, 2013 Posted September 6, 2013 Adam is correct. OEM discs are supplied with bearings whereas aftermarkets are not. We have plenty of bearing kits in stock if you need them, would be with you tomorrow. Quote
hutchy1990 Posted September 6, 2013 Author Posted September 6, 2013 Can you remove the old bearings for the old ones? Quote
klyfax Posted September 7, 2013 Posted September 7, 2013 Don't take the old bearings. You will drive 1000 miles, then the old bearings need to be changed into new ones. And its a pain in the ass getting old bearings out with out destroying them. Do it right first time, buy new bearings. Quote
hutchy1990 Posted September 8, 2013 Author Posted September 8, 2013 Yeah I see your point mate I have got a refund on the ones I bought without bearings and I just bought the ones with bearings from ID works so all sorted Quote
