my ep91 is running standard boost at the moment and fitted a fmic so wondering what is the best way to turn up the boost?
Boost gauge fitted already and wondering what is the most you can turn up the boost without any damage?
cheers in advance :D
only a standard ECU at the moment, what is the best ECU to get ?
yh got boost gauge fitted already running 0.5 which im guessing is standard?
is it best to get electronic boost controller?
Depends what you what out of the car if sticking with ct9 or hybrid alternatives I found the jam ecu excellent. You will need a boost controller to increase the boost, 0.8 is standerd boost the 0.5 must have been in a low gear so I'm guessing that you haven't uncrossed your boost pipes to give you full boost in all gears?
I think you will need a adjustable actuator aswel, best of looking in the technical discussion section you probably wont even need to post all the answers to questions asked over and over again are there just scroll through this forum is great for finding out everything you need to know about your car. I'm pritty sure there is a write up in the wiki section of the forum telling you how to get the most out of your ct9 :-)
