stockrod Posted September 14, 2013 Posted September 14, 2013 I am after the aluminum item you can see in the picture from a older 4e from a "ep82", as a ep91 4e item does not fit / line up on a older a ep82 4e block. Hence the difference in the sumps aswell. Or if anyone could provide a part no? Many thanks.
stockrod Posted September 18, 2013 Author Posted September 18, 2013 BUMP. Still needing the above, must be from a pre 96 engine tho. Typically found in a ep82.
akyakapotter Posted September 18, 2013 Posted September 18, 2013 Think this is the toyota part number bud11381RETAINER, ENGINE REAR OIL SEAL 11381-10020
stockrod Posted September 19, 2013 Author Posted September 19, 2013 Excellent i shall look into it. Thanks
karl. Posted September 19, 2013 Posted September 19, 2013 I seen one of these in my shed yesterday evening. Im not sure what engine its for but if you find out I can check for you?
stockrod Posted September 19, 2013 Author Posted September 19, 2013 It seems with a slight modification and i have managed to get it to fit like oem. Thanks all.
