James21 Posted September 17, 2013 Posted September 17, 2013 As title? Trying with a hairdryer and making a mess :-( lol Quote
Idrees Posted September 17, 2013 Posted September 17, 2013 Don't even bother mate, they don't come off easy (at all)! Out of interest, why do you want them off? Quote
TurboTobz Posted September 17, 2013 Posted September 17, 2013 pre heat oven, pop it in, take it out after a few mins, pry lens back with a screw driver or similar if it's not coming away pop it back in and try again after a few mins. Not done it with glanza lights but have done it with other plastic and glass lenses. Always been fine Quote
James21 Posted September 17, 2013 Author Posted September 17, 2013 Don't even bother mate, they don't come off easy (at all)! Out of interest, why do you want them off?Some dirt has got in while theyve been off and its congealed on the chrome inside... Doesn't look great... Ill get a photo and you can tell me wether its worth taking it off lol pre heat oven, pop it in, take it out after a few mins, pry lens back with a screw driver or similar if it's not coming away pop it back in and try again after a few mins. Not done it with glanza lights but have done it with other plastic and glass lenses. Always been fineWould that not melt the plastic aswell as the glue? Cheers Quote
TurboTobz Posted September 17, 2013 Posted September 17, 2013 Nope, it's a common way of doing it Quote
James21 Posted September 17, 2013 Author Posted September 17, 2013 You can just see it in the photo, its like some dirty water has slipped in through the bulb hole... Quote
TurboTobz Posted September 17, 2013 Posted September 17, 2013 Don't be afraid of the oven once you get it to theright temp they usually come off with minimal effortI was going to do mine for this reason and my lenses appeared to be glazed on the inside, I sold my glanza before I got around to doing it Quote
James21 Posted September 17, 2013 Author Posted September 17, 2013 What temp would you set the oven? And would it just be a case of taking it out and trying to pull it off every minute or so? Cheers Quote
TurboTobz Posted September 17, 2013 Posted September 17, 2013 180 degrees area, just keep your eye on it, and keep trying it Quote
James21 Posted September 17, 2013 Author Posted September 17, 2013 Right ill do it in morning with a fresh head lol cheers mate, appreciate it (Y) Quote
TurboTobz Posted September 17, 2013 Posted September 17, 2013 (edited) No probs, there'll be guides about on the net... Namely on saxo and shitbox forums because they take they're lights apart to spray em black because' dey is badamanabananas. I've done a set of shitshroen shitbox ones for some one they're nicer as they are glass, real easy, a set of 206 fogs for a friend as the chrome peeled so I sprayed them black, a set of my old clio ones as there was a fault with a projector and a set of ibiza cupra ones of my own as they'd been replaced for the silver ones and were meant to be black internally.Never had any issues, the only thing thats annoying is they usually deform slightly around the lip where you pry it open so be sure to do it on the bottom of the lights so it's not visible when you place them back on there car (shit like this bugs me personally). Putting them back together is just back in the oven heat the glue and pop em in, i've also been told impact adhesives good for resealing if required. Edited September 17, 2013 by TurboTobz Quote
James21 Posted September 17, 2013 Author Posted September 17, 2013 No probs, there'll be guides about on the net... Namely on saxo and shitbox forums because they take they're lights apart to spray em black because' dey is badamanabananas. I've done a set of shitshroen shitbox ones for some one they're nicer as they are glass, real easy, a set of 206 fogs for a friend as the chrome peeled so I sprayed them black, a set of my old clio ones as there was a fault with a projector and a set of ibiza cupra ones of my own as they'd been replaced for the silver ones and were meant to be black internally.Never had any issues, the only thing thats annoying is they usually deform slightly around the lip where you pry it open so be sure to do it on the bottom of the lights so it's not visible when you place them back on there car (shit like this bugs me personally). Putting them back together is just back in the oven heat the glue and pop em in, i've also been told impact adhesives good for resealing if required.Ive got some aquarium sealent i was gunna use to put em back together... Waterproof so would work, but if its as simple as heating the existing glue and sticking it back together ill do that! Quote
