EPnick22 Posted September 20, 2013 Posted September 20, 2013 how much would the compression drop by when using a 1.9mm gasket compared to a 1.4? or a 1.2 even.... Quote
ryan lang Posted September 20, 2013 Posted September 20, 2013 0.5mm? haha depends on if you've had the head skimmed, what pistons your using? Quote
EPnick22 Posted September 20, 2013 Author Posted September 20, 2013 9.0 compression Wiseco pistons, head hasnt been skimmed, I was going to get it done but its straight and flat as it should be, surprisingly... Quote
ryan lang Posted September 20, 2013 Posted September 20, 2013 id work it out for you but im unsure on the combustion chamber volume Quote
EPnick22 Posted September 20, 2013 Author Posted September 20, 2013 take a read of the other thread talking more in depth about it http://www.ukstarletowners.com/topic/70509-higher-compression-retard-timing/ Quote
