(NAS) starlet ep82 Posted September 27, 2013 Share Posted September 27, 2013 http://www.ebay.co.uk/itm/Millers-Oils-CRX-LS-80w-90-NT-Competition-Semi-Synthetic-Gear-Oil-1L-/400552264600?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d42c68398 previous owner used semi synthetic LS90 MILLERS gear oil the one above on the link is LS-80/90 is this the same as the LS90 oil ? as its closest i could find recently i changed my gearbox oil on mates car & his box is soo loudon full locks its so unbelievably loud/clunks like somethings about to break but as soon as u turn either side full lock with clutch down thres no noise at all CUSCO LSD previous owner used LS90 semi synthetic gear oil, where would i get this from?? or do i use the one on the link above reli need help ASAP as i have used some cheap oil called ''Granville LS 80/90'' atmo.. my diff was fine before changing the oil cheers Quote Link to post Share on other sites
Ep'd Posted September 28, 2013 Share Posted September 28, 2013 Thought this was the steering rack causing the clunk? Quote Link to post Share on other sites
AdamB Posted September 28, 2013 Share Posted September 28, 2013 I've told you about 3 times over on TGGT. Quote Link to post Share on other sites
(NAS) starlet ep82 Posted September 29, 2013 Author Share Posted September 29, 2013 I've told you about 3 times over on TGGT. yeah i know bud but not sure which grade to use as theres loads of different oneson that page,but i've managed to speak to someone local &ordered some so thanks for your help guys will let u know how i get on Quote Link to post Share on other sites
