The ones I know off the top of my head will be :
C52, C56, OEM LSD (will need driveshaft) and the Corolla G6 box, but that requires a few different bits.
hey adam i got a question on this as well a guy down here brought a gear box for me me to fix he needs his second gear replaced... he bought a spare gear box and it has a original lsd in it ... its for a 4age engine would the lsd from it work in my car??? he said hed pay in parts aka i could have the lsd if i want it... but ill only do it obviously if it will work in the gt gear box
It will fit the box for sure. Just mount it in your final drive ring gear.
I would check driveshaft fitment before going ahead though.
They are a brilliant LSD for a stock item. Transformed my car!
ahhhhhhhhh i miss read that my bad i saw stock set up not stock item ....
in that case bring on the gear box its time to get fixing.... i could do with a free lsd.... that would take a lot of expense of my shoulders as i was looking at a quaife... doubt its as good but again its FREE for a few hrs of work
Edited by rasslenny
HAha yeah.its good considering its an OEM LSD.
Cant say how good it will be with 5e power going though it but with 170hp 120lbft its really good just launches you to the inside of corners that normally you'd be begining to understeer around lol
But just check a 4efte inner cv in it before you take all yours apart ;)
good to know and even if it aint that good with 235hp it cant be worse than stock now can it
and will do the gear box is arriving tomorrow so when i get it out as the engine isnt in the car and the drive shafts are just dangling ill stick em in and make sure everything is just dandy
