Am not sure I have never taken them off am sure if you make you way around the column should be straight forward once you open it up..
I did this today mate, the bolts dont come out the just loosen... You have to put a screw driver under the airbig part and prise one of the bolts out of its clip... Then the other side slides out... But as gainzy said, disconnect the battery so the airbag doesn't deploy... (y)
