rally steering wheel horn problem
I have fitted a OMP Boss and steering wheel on my ep91 SR. Removed the airbag now problem with horn. I have had a suggestion I use a switch from a non air bag car that would sit under the bass ring at the bottom of the boss. Any ideas folks please if this works does anyone have this part.
The SR has the 3spoke wheel same as a 98 glanza. The airbag is electric. You need the horn/steering coloumn bit from a manual airbag model, 96-98
Its the bit with the brass pin and spring that sticks out to touch the brass ring on the rear of the boss. Put plenty of grease on the pin and rememver to centre the indictor ring (blackyellow thing) before u fit the wheel or the indictors wont turn off when they should
  • 2 months later...
