scutch0 Posted September 30, 2013 Posted September 30, 2013 I'm having an issue that I think is shock absorber related, so I'm wondering if anyone has a pair or rear shocks in used but working condition they don't need? As I'm not sure if it's a separate issue I'm after a cheap pair as I might not end up needing them.I'm also after a set of lowering springs that offer a bit of rake, mine are an even drop and I need a little more rear clearance.Both cheap as chips preferably, and unless you're close I'll need a delivered price.
Ollieh17 Posted September 30, 2013 Posted September 30, 2013 I have a set of rear shocks with lowering springs i replaced as i thought they were broken but turned out to be the fronts. They have 40mm lowering springs on them already. I can send them out for £50 posted?
