Hunty Posted October 7, 2013 Share Posted October 7, 2013 My luck continues with the starlet haha My car has been making a high pitched scream sort of sound recently which has had me worried I had a look and my turbo housing seems to be loose I can rotate the turbo a little by holding the hot pipe and moving this. Is there a way I can rectify this or will it have to be rebuilt? Many Thanks Brad Quote Link to post Share on other sites
mikey4410 Posted October 7, 2013 Share Posted October 7, 2013 If the little location pin is removed it will move round but it shouldnt move easyily. Quote Link to post Share on other sites
AdamB Posted October 7, 2013 Share Posted October 7, 2013 Chances are it will need rebuilt if the compressor has been in contact with the housing. Quote Link to post Share on other sites
Liam_D Posted October 7, 2013 Share Posted October 7, 2013 You should be able to tighten it up. But chances are there's a reason it's came loose. But yeah as Adam said it will probably need a rebuild just to make sure the comp wheel hasn't had contact with the compressor housing. If you need a rebuild or even it looking at give me a shout ;) Quote Link to post Share on other sites
Hunty Posted October 9, 2013 Author Share Posted October 9, 2013 Ok cool thanks for the replies I will take it off and have a look it was coming off the road end of this month for the winter so if it does need anything i will take it off early and use my work horse lovely escort van haha Quote Link to post Share on other sites
