liss Posted October 10, 2013 Share Posted October 10, 2013 Hey guys, The warm air from my heater in my Glanza V tends to fog up the windscreen no matter what the weather is outside, and even after then it takes ages to clear! Do any of you guys know what the problem is? We've heard it could be the cabin filter or something to do with the air con - which has been removed anyway! If you could help I'd be forever thankful as I kinda need warmth now it's getting colder! Thank you in advance!! Quote Link to post Share on other sites
Brent Keppens Posted October 20, 2013 Share Posted October 20, 2013 I think you might've set the heater wrong. Look at this picture make sure the air circulation is set from outside and the heating is set to your windows. Quote Link to post Share on other sites
morgey Posted October 20, 2013 Share Posted October 20, 2013 Pollen filter under the passengers side dash, if its got full of crap and wet then it can cause it. It's 2 separate filters, mkst motor factors or id imagine id-workz can get them. Worth doing as it makes the blowers stronger too Quote Link to post Share on other sites
