smithyithy Posted October 15, 2013 Posted October 15, 2013 Ar. From what I can gather, cause my V has a double-DIN headunit, the plastic strip that once separated the 2 single-DIN's is gone, does that make sense? So, if I want to go back to a single-DIN headunit and a standard cubby slot or one of those triple gauge displays, what are my options? Can I just stack 2 single-DIN units on top of each other in the slot? Is there any kind of adapter or bracket I can fit? Or will I have to find a replacement fascia? And if so, is that an easy swap? Thanks. Quote
Jap91 Posted October 21, 2013 Posted October 21, 2013 There is two brackets you need mate.. They screw in too your single din headunit and cubby tray.. Some one probly has one in the breaking section or put up a wanted add Quote
smithyithy Posted October 21, 2013 Author Posted October 21, 2013 Cheers dude, I'm on the hunt ;) Quote
Jap91 Posted October 22, 2013 Posted October 22, 2013 Can get you a flip down face cubby hole if your interested.. Quote
cherrye10 Posted November 11, 2013 Posted November 11, 2013 i retain double din. it looks more jap. and a factory-option at that to keep it more authentic Quote
littlegreenmonster Posted December 1, 2013 Posted December 1, 2013 My starlet has a hole for double din but has a singlet din head unit and a black piece of plastic satin starlet underneath which bolts into a thin metal frame same as my radio Quote
JDMfreak Posted December 1, 2013 Posted December 1, 2013 you can go this way about it or if your luck you might find a pocket in the breakers that will fit or fit some gauges in there Quote
