EP82 rev counter just stopped working!
Iirc the rev counter is electronic so can only be the rev counter or wiring to it/from where signal is picked up(ecu I believe) so that's where to start your search for broken wires etc. take the clocks out nearly all the way and check plugs on back of clocks (could be a dry joint and a jiggle could sort the problem) if still no luck I have a rev counter here from a set I bought when I needed a fuel gauge. Hope that helps
Edited by Kyle_R
I have the same problem, but this happened after installing after market ecu - where is the signal wire on the Rev counter looked every where and could not resolve this. Heat gauge is all the way to the top - so we night have cut a common wire - can anyone help please.
Thanks Bertie
