AdamF Posted October 31, 2013 Share Posted October 31, 2013 Anyone know why? Thanks Adam Quote Link to post Share on other sites
Kyle_R Posted October 31, 2013 Share Posted October 31, 2013 (edited) Iirc the rev counter is electronic so can only be the rev counter or wiring to it/from where signal is picked up(ecu I believe) so that's where to start your search for broken wires etc. take the clocks out nearly all the way and check plugs on back of clocks (could be a dry joint and a jiggle could sort the problem) if still no luck I have a rev counter here from a set I bought when I needed a fuel gauge. Hope that helps Edited October 31, 2013 by Kyle_R Quote Link to post Share on other sites
Bertie Posted November 7, 2013 Share Posted November 7, 2013 I have the same problem, but this happened after installing after market ecu - where is the signal wire on the Rev counter looked every where and could not resolve this. Heat gauge is all the way to the top - so we night have cut a common wire - can anyone help please. Thanks Bertie Quote Link to post Share on other sites
Bertie Posted November 8, 2013 Share Posted November 8, 2013 bump Quote Link to post Share on other sites
