avster Posted October 31, 2013 Share Posted October 31, 2013 (edited) Hi guys so heres the thing i live in Botswana and want to have a manifold for a TD04 conversion made up because it would be too expensive for me to import one. All i need to know is what size piping to use to make the manifold thats the internal diameter as well as the type of material and also the wall thickness of the piping as i was going to use mild steel.I already have the turbo as well as all the flanges required. Edited October 31, 2013 by avster Quote Link to post Share on other sites
goldenvtr Posted November 3, 2013 Share Posted November 3, 2013 Hi guys so heres the thing i live in Botswana and want to have a manifold for a TD04 conversion made up because it would be too expensive for me to import one. All i need to know is what size piping to use to make the manifold thats the internal diameter as well as the type of material and also the wall thickness of the piping as i was going to use mild steel.I already have the turbo as well as all the flanges required. I've'e used mild steel sch10 1.25" which i belive is 3mm thick Quote Link to post Share on other sites
