gettin a friends gt starlet together in the next few weeks,will be running a k24,upgraded injectors and an emanage ultimate.
im not puttin a walbro in it as i have seen too many fail to trust them
so a sard pump is what im thinkin
280 would be way over kill i think very big fit compared to the 235 126x51 mm to 114x38 mm
http://www.rhdjapan.com/sard-high-flow-fuel-pump-universal-280l-h.html
http://www.rhdjapan.com/sard-high-flow-fuel-pump-universal-235l-h.html
TD's actually look like a walbro item anyways. I've never seen one fail, literally everyone with a modified starlet runs on. Could leave the standard one in there as a lift pump to a swirl pot, then use a Bosch 044 on that.
Well each to their own, thats why i suggested the other option. It wouldn't matter if you went for a 280LPH pump aswell as the fpr regulates the flow anyway. Your fuel would just be slightly warmer as it would be cycling through the system more.
