Ramsey Posted October 30, 2007 Share Posted October 30, 2007 wot mods do i need 2 do when fitting a scooby tdo4 turbo? Quote Link to post Share on other sites
Guest Enzo Posted October 30, 2007 Share Posted October 30, 2007 quite a few buddy, you need to buy a kit with a manifold=, oil lines etcits quite extensive Quote Link to post Share on other sites
Shorty Phil Posted October 30, 2007 Share Posted October 30, 2007 from speedvision the kit will set you back just short of £800 all parts including injectorsOnly things you will need extra if you dont have them is RRFPR Uprated fuel pumpand some sort of extra or standalone management Hoep this help chap Quote Link to post Share on other sites
Glanza_Ragger Posted October 30, 2007 Share Posted October 30, 2007 Then to really get any proper boost out of a td, you would want to look at getting stronger internals.People do run td's on standard internals but if it were me, id forge so you can boost higher. Quote Link to post Share on other sites
Shorty Phil Posted October 30, 2007 Share Posted October 30, 2007 well on mine ive got ordered and awaiting delivery 74.5 ross racing pistones and a 1.4mm head gasket much better for higher boost and alot safer to run the higher boost Quote Link to post Share on other sites
Glanza_Ragger Posted October 31, 2007 Share Posted October 31, 2007 well on mine ive got ordered and awaiting delivery 74.5 ross racing pistones and a 1.4mm head gasket much better for higher boost and alot safer to run the higher boostGood man ;) Are you keeping the original revlimit? Or are you thinking about upping it at all?Also are you going to run the forged pistons with standard rods? Quote Link to post Share on other sites
Shorty Phil Posted November 1, 2007 Share Posted November 1, 2007 yeah forged with std rods mate ......I aint thought about the limietr at all yet tbh will my rods be good for a safe 250bhp as thats my aim in the end... also what is a safe limiter ? for the td04 setup ??? Quote Link to post Share on other sites
Shorty Phil Posted November 1, 2007 Share Posted November 1, 2007 my aim is for my full setup to be safe and reliable....Engine will have full new gasket set pump and all pulleys are perfect the cams are mint and so is the crank.. I'm changing the big end and main shells aswell so the engine should be in A1 condition with any luck.. Quote Link to post Share on other sites
Glanza_Ragger Posted November 1, 2007 Share Posted November 1, 2007 Well if youre doing all that work , id think about changing the rods whilst youre at it.You may as well when its apart, saves you time and hassle if you need/decide to in the future.Standard revlimit will be fine with a td04, allthough some people take it slightly higher becuase of the slight extra lag before the td boosts.Allthough saying that, there not too laggy so its all down to preference.If you decided to take the revlimit up, think about uprated valvesprings,lifters etc.Dont want to be upsetting the valves when youre revving harder Should be a nice build as the td's are proven to be brilliant turbos to run with.Which type of td04 is it bud? Quote Link to post Share on other sites
Shorty Phil Posted November 2, 2007 Share Posted November 2, 2007 going to get the td04l from speedvision in there kit.... Well i aint uprating the ords as ive had to buy yet more other things just to get it back on the road lol i might raise it a lil ill see how i go im still thinking of billet cams for nect year hmmmm... decision decision decision lol Quote Link to post Share on other sites
carter Posted October 19, 2008 Share Posted October 19, 2008 i just had the wepr kit put on.that the one from toy tuning with the td04 turbo the parts was ok but the kit i got was missing a hell of alot of stuff ie the small thing like hoses and bolts and a few fitting which had to be haded up. it all so takes a hell of a lot of work to put this kit on. i would say yes the td04 is a killa up graded for the car but the down sided from what you need and the time it takes to put it on and the extra stuff you need very very pricie mod to do. but if you got the oney to burn i say go for it. it will put a smile on your face. Quote Link to post Share on other sites
