marble Posted November 6, 2013 Posted November 6, 2013 As it says on the title can anyone help my v is too low for the pipes to go under the bumper. anyway they can be relocated? Quote
marble Posted November 7, 2013 Author Posted November 7, 2013 Think it's jpperformance one mate Quote
russ78 Posted November 7, 2013 Posted November 7, 2013 As it says on the title can anyone help my v is too low for the pipes to go under the bumper. anyway they can be relocated?Under the bumper ? They normally sit behind bumper Quote
Vturbo Posted November 7, 2013 Posted November 7, 2013 With my jperformance intercooler the piping was slightly lower than the bumper Quote
marble Posted November 7, 2013 Author Posted November 7, 2013 Under the bumper ? They normally sit behind bumperSorry I meant lower than the bumper With my jperformance intercooler the piping was slightly lower than the bumperAnyway that can be fixed? Quote
Ollieh17 Posted November 7, 2013 Posted November 7, 2013 can you not move the core up which would then move all the pipes up? Quote
marble Posted November 7, 2013 Author Posted November 7, 2013 can you not move the core up which would then move all the pipes up?Nah dude the pipes go under a part of the car not sure what it's called I'll get a picture tomorrow Quote
Vturbo Posted November 8, 2013 Posted November 8, 2013 Sorry I meant lower than the bumper Anyway that can be fixed?To be honest it's alright clearance wise. I had to cut the splash guard to fit around the piping if that's what you mean? Quote
Zeldoz Posted November 8, 2013 Posted November 8, 2013 Take your front bumper off, and move the core up. I had to do the same. Your piping will go under your subframe. If you move it up the pipes will still reach. You may need to loosen the ones closest to the incooler to adjust them etc. But after that your have no issues. See my build thread for reference, your see how badly it hung out until i moved it up! Quote
marble Posted November 9, 2013 Author Posted November 9, 2013 Take your front bumper off, and move the core up. I had to do the same. Your piping will go under your subframe. If you move it up the pipes will still reach. You may need to loosen the ones closest to the incooler to adjust them etc. But after that your have no issues. See my build thread for reference, your see how badly it hung out until i moved it up!Thanks mate I'll look into it! Quote
