Ghost 12 Posted November 8, 2013 Posted November 8, 2013 Hello i have a ep95 with the 4efte engine and the cooling fan runs if i turn on the ignition.i drive the car without air conditioning but i put in the senosr for it.but the fan doesnt stop. please can anybody help me? i have changed the fansenor but it doesnt help. thanks Quote
morgey Posted November 9, 2013 Posted November 9, 2013 The fan runs through a relay, if the signal from the sensor is lost the fan turns on as an fail safe.If the sensors ok, I would say a split wire is your problem Quote
Ghost 12 Posted November 9, 2013 Author Posted November 9, 2013 hmm okay but if i plug it off the fan stops. hmm i will check the relay Quote
morgey Posted November 9, 2013 Posted November 9, 2013 If you unplug the sensor it stops? Is this for the normal fan or aircon fan? Quote
Ghost 12 Posted November 11, 2013 Author Posted November 11, 2013 yes it stops if i unplug it. for the normal fan. Quote
Ghost 12 Posted November 14, 2013 Author Posted November 14, 2013 so i put in a green and a white switch but the same problems. anybody an idea? thanks Quote
corofin12345 Posted November 14, 2013 Posted November 14, 2013 (edited) i dont know whats going on but when ya unplug that sensor (fan sensor) with ignition on, the fan should come on, not go off.. have you the a/c connector bridged and what loom your using..?? glanza loom = nothing needs to be done once a/c is removedGT loom = a/c connector has to be bridged to stop fan from running constant Edited November 14, 2013 by corofin12345 Quote
