Basically ive changed my headlights because a bulb was out i replaced all of them..
Refitted and now my drivers side main and dipped dont work at all. All left lights work and rh sidelight.
Also the high beam light in the dash has stopped working? Im going to inspect the wiring behind the quad lights tomorrow but has anyone got any ideas before i strip all the light unit out?
Ep82 quadlight
Thanks
Might not be the earth reading your post again, but worth a try. Its right in the corner in the bay, where the washer bottle is if you dont have ABS or if you do its still in the same place but its infront of the ABS pump.
Easy to see, 10mm bolt through it.
I feel your pain mate, i started mine tonight to warm up to go home and no dipped or high beam,
Mines a ep82 quad running HID's on dipped,
Just checked all fuses there fine, unplugged it all and replugged it in, still no joy :(
But i have had a smell of burning clutch/brakes inside the cabin, but not outside,
Help is much appreciated :)
Sorry to blag your post mate
