Dusty Posted November 13, 2013 Share Posted November 13, 2013 As abobe says on the cap dot 3 but the local garrage only has dot 4 anyone recomend and good oil I can buy online, or will any dot 3 do? Cheers dusty Quote Link to post Share on other sites
daniel_g Posted November 13, 2013 Share Posted November 13, 2013 Toyota dot 5.1 is what most of use, thats fine for kinda fast road use, you can get other more expensive stuff for track use though. Quote Link to post Share on other sites
Dusty Posted November 13, 2013 Author Share Posted November 13, 2013 Ok cheers bud I'll have a search on google see what it brings up Quote Link to post Share on other sites
oilman Posted November 14, 2013 Share Posted November 14, 2013 Hi The best fluids for the brakes and clutch are the Castrol SRF, Motul RBF660 and Gulf RF1000. The Motul RBF600, Gulf RF1000, Millers 300 Plus and Fuchs Pro Race are close to those, but don't have quite as high boiling points. Those ones are all really for cars that are used on track. The next step down (in performance terms), but still an upgrade over standard are the Gulf Racing 5.1, Motul DOT 5.1 and Castrol React Performance. Any of the other DOT4 fluids we have are fine to use as a standard choice. http://www.opieoils.co.uk/c-450-brake-fluid-clutch-fluid.aspx CheersTim Quote Link to post Share on other sites
Idrees Posted November 14, 2013 Share Posted November 14, 2013 As Dan said, the most common is Dot 5.1. Many of us use the genuine Toyota fluid, we keep it in stock too. Quote Link to post Share on other sites
Dusty Posted November 14, 2013 Author Share Posted November 14, 2013 Cheers idrees i will get some orderd from u some time soon Quote Link to post Share on other sites
