Spoon_tuned Posted November 18, 2013 Posted November 18, 2013 Hi guys some of you may know i've had a few problems with oil leaking from my glanza. Well i have had the crank seal changed and the cam seal…and there's still a leak now i'm thinking oil pump seal as i can see it dripping from that area deffo not the sump or rocker cover. Had this changed: What Is This Seal:? Is there an inner and out oil pump seal??? Quote
Jamie_VF22 Posted November 18, 2013 Posted November 18, 2013 (edited) There is two types of oil pump one with a seal , And one does'nt have the seal you need to get the right one But the seal is on the inner on the pump Edited November 18, 2013 by Jamie_VF22 Quote
Spoon_tuned Posted November 18, 2013 Author Posted November 18, 2013 There is two types of oil pump one with a seal and one does'nt have one you need to get the right one But the seal is on the inner on the pump can you verify which has the inner seal?? i wanna order the seal but unsure if mines the one without one Quote
Jamie_VF22 Posted November 18, 2013 Posted November 18, 2013 Looking at your pump you need the one with seal buddy Quote
Spoon_tuned Posted November 18, 2013 Author Posted November 18, 2013 Looking at your pump you need the one with seal buddy sorry mate thats not my pump it's just a picture off the net i need somebody to confirm if i need the seal i would of thought i did as it's leaking from there i think Quote
Jamie_VF22 Posted November 18, 2013 Posted November 18, 2013 (edited) Thought it was yours mate not really going to no till you have removed it but like you say its leaking from there so i would say you need the one with the seal Edited November 18, 2013 by Jamie_VF22 Quote
Spoon_tuned Posted November 18, 2013 Author Posted November 18, 2013 Thought it was yours mate not really going to no till you have removed it but like you say its leaking from there so i would say you need the one with the seal ok i might just order one there only £5.99 Quote
Spoon_tuned Posted November 18, 2013 Author Posted November 18, 2013 Can anyone else confirm the seal?? Quote
