Is there Anyone about Aberdeen that would be able to look at my Glanza? Was driving the car Friday and the heaters just started blowing cold air not hot. Changed the thermostat today but no joy. ££ paid ofcorse!
Heater matrix will piss water out, check your water level aswell. If it's dropped, fill it up and monitor it for a few days. Also as Jord says is it getting upto temp or going to high?
John
The lever rod is there and working lol, and also topped up coolant. It's getting upto temp fine and holding half way on the gauge as it always has, been told it must be water pump as the heat ain't making it to the heater matrix?
Are the pipes in the engine bay going through the bulkhead hot? If not then the water won't be getting to the matrix otherwise the lever rod wont be opening the vent as CAT said
Ahh I misunderstood the lever vent lol, that behind the centre console I take it? I haven't checked in behind there, yeah the two heater matrix pipes going through the bulkhead are hot..
Checked the wire behind the hot and cold control and all is connected, only thing it can
Be is heater matrix? As there's heat going into the bulkhead and coming out the outlet.
Edited by scottmac1
If you end up having to take it to a garage, give CMB Autos a shout, Mark knows starlets inside out, they are in pitmedden
