As above since removing air con,i am aware that you have to bridge a sensor, however where is it,and which terminals do you bridge?
Thanks.
Should be a plug on the n/s inner wing that went into a sensor on the a/c pipes. Can always pop the senso back in. Can remember the wires to bridge. Can put a multi meter over the sensor to work out the bridge
