karl. Posted November 26, 2013 Posted November 26, 2013 Can somebody confirm that this will work in a glanza? I know you either have to grind down this or the power steering rack but will this work with the standard filter and fit ok? http://pages.ebay.com/link/?nav=item.view&id=360765142777 Quote
Jamie_VF22 Posted November 26, 2013 Posted November 26, 2013 Yes pal it will work but as you say you will have to grind it down abit pal I used to run the same one Quote
whitestar Posted November 26, 2013 Posted November 26, 2013 Sorry for jumping in like this to your thread but is it possible to arrange the oil supply for a stock ct9 with this when turboing 4EFE? Or is it easier just to get a FTE oil filter housing/bracket? Quote
Jamie_VF22 Posted November 26, 2013 Posted November 26, 2013 Sorry for jumping in like this to your thread but is it possible to arrange the oil supply for a stock ct9 with this when turboing 4EFE? Or is it easier just to get a FTE oil filter housing/bracket? You will need the FTE oil filter housing, If you are turboing a 4EFE engine boss Quote
whitestar Posted November 26, 2013 Posted November 26, 2013 Ok, thanks for the info. Off to drill some more holes for a few screws then, eh? Quote
karl. Posted November 26, 2013 Author Posted November 26, 2013 Yes pal it will work but as you say you will have to grind it down abit pal I used to run the same one Thats all I needed to know, great. Thanks Quote
Jamie_VF22 Posted November 26, 2013 Posted November 26, 2013 Thats all I needed to know, great. Thanks Your welcome mate Quote
whitestar Posted November 26, 2013 Posted November 26, 2013 What about this one, seems like the turbo oil feed is taken from the sandvich plate? Sorry KidV for borrowing you pic here. Quote
