sosolid Posted November 26, 2013 Posted November 26, 2013 had a look at me spart plugs and found that number 1 had alot of oil on the bit that screws into the cylinder i think they call it the thread and number 4 had a little. 3 and 4 were dry. wats causing this. Quote
Glanza-Ben Posted November 26, 2013 Posted November 26, 2013 It's the spark plug seals on the rocker cover I've just brought new ones from id works there cheap as chips Quote
Nick85 Posted November 26, 2013 Posted November 26, 2013 What Ben said. Just don't go to Toyota like I did lol. You will cry at their prices Quote
sosolid Posted November 26, 2013 Author Posted November 26, 2013 Thanks guys also wen u change the rocker gasket do u have to put sealent so it stays on wen u turn to put it bk on. Isit easy to change dem Quote
Zeldoz Posted November 26, 2013 Posted November 26, 2013 Thanks guys also wen u change the rocker gasket do u have to put sealent so it stays on wen u turn to put it bk on. Isit easy to change dem My gasket pushed into place, didn't use sealant and its not leaking. I check everyday! Quote
Nick85 Posted November 26, 2013 Posted November 26, 2013 My gasket pushed into place, didn't use sealant and its not leaking. I check everyday!Yeah exactly what I done and not having any issues Quote
Chris_GlanzaV98 Posted November 26, 2013 Posted November 26, 2013 when refitting the rocker gasket be sure to scrape any old gasket off the rim of the head, this will ensure a better seal Quote
