garrygt Posted November 26, 2013 Posted November 26, 2013 What map sensor can i run with this ecu? Would i be best off getting a proper apexi one if i can? Also do i need anything else to run this ecu? Quote
DevonGT Posted November 26, 2013 Posted November 26, 2013 You can pay out for an Apexi one or use a VW one. Quote
TrisK Posted November 26, 2013 Posted November 26, 2013 What map sensor can i run with this ecu? Would i be best off getting a proper apexi one if i can? Also do i need anything else to run this ecu?or a 3bar mr2 one Quote
DevonGT Posted November 26, 2013 Posted November 26, 2013 This is what i done - http://www.toyotagtturbo.com/forums/showthread.php?91364-Apexi-power-fc-alternative-3bar-map-sensor.&highlight=apexi+sensor Quote
Foggy Posted November 26, 2013 Posted November 26, 2013 You can use a gen6 gt4 celica either.Direct plug in Quote
garrygt Posted November 26, 2013 Author Posted November 26, 2013 Cheers lads. Think i will go with the mr2 or gt4 map sensor Quote
garrygt Posted November 26, 2013 Author Posted November 26, 2013 Happy days min. Give me a shout if you find itm Quote
