garrygt Posted November 26, 2013 Share Posted November 26, 2013 What map sensor can i run with this ecu? Would i be best off getting a proper apexi one if i can? Also do i need anything else to run this ecu? Quote Link to post Share on other sites
DevonGT Posted November 26, 2013 Share Posted November 26, 2013 You can pay out for an Apexi one or use a VW one. Quote Link to post Share on other sites
TrisK Posted November 26, 2013 Share Posted November 26, 2013 What map sensor can i run with this ecu? Would i be best off getting a proper apexi one if i can? Also do i need anything else to run this ecu?or a 3bar mr2 one Quote Link to post Share on other sites
garrygt Posted November 26, 2013 Author Share Posted November 26, 2013 Is a mr2 one the same plug? Quote Link to post Share on other sites
DevonGT Posted November 26, 2013 Share Posted November 26, 2013 This is what i done - http://www.toyotagtturbo.com/forums/showthread.php?91364-Apexi-power-fc-alternative-3bar-map-sensor.&highlight=apexi+sensor Quote Link to post Share on other sites
Foggy Posted November 26, 2013 Share Posted November 26, 2013 You can use a gen6 gt4 celica either.Direct plug in Quote Link to post Share on other sites
garrygt Posted November 26, 2013 Author Share Posted November 26, 2013 Cheers lads. Think i will go with the mr2 or gt4 map sensor Quote Link to post Share on other sites
starletgt-shady Posted November 26, 2013 Share Posted November 26, 2013 I might have a spare Quote Link to post Share on other sites
garrygt Posted November 26, 2013 Author Share Posted November 26, 2013 Happy days min. Give me a shout if you find itm Quote Link to post Share on other sites
